Need help with smt6 (ENG)
Hi guys! Please could you help me with connection of smt6 to non cat uno 1,3turbo Because when I connet like in cat version, It wont start an in the bottom of the screen is error: bad - rpm , please if anybody knows whats going on help me. THANKS
Cut cable connected to pin 1 to Microplex. Side from sensor connect to the yellow from smt6, and pink from smt6 connect to 1 in your Microplex.
In global settings set as below:
Cylinders 4,
-Teeth per turn(incl miss) 2,
-Teeth per firing 1,
-Modes 10 or 13,
-System Config:
Positive input pol ON,
Positive output pol ON,
Cylinders 4,
-Modes 10 or 13,
-System Config:
what can I try next
hello guys!
everything is connected like you tell me and still the same error appears BAD RPM and it doesnt starting, should I use green microplex??? or what? thanx
Did you try just to connect to the ingition signal without cutting it?
redlineturbo pisze:do u mean connecting yello and pink wires to the pin 1 cable without cutting this cable? I dont understand how can work can u tell me more please and what type of ecu/piggy back are u using now?
connect just yellow wire to the pin 1, then you should see rpm
if you dont try to connect directly to the TDC sensor
Now I'm using ECUMASTER piggyback, similar to the smt6 but it have a few useful options like launch controll and direct injection time cotrol
redlineturbo pisze:okey I try it tomorrow , is there any english site about ecumaster and e shop?
I think there isn't any, ecumaster is a polish computer
If you have any questions regarding Ecumaster feel free to email me: colin@ecumaster.com
Best regards,
Tom
Best regards,
Tom
